Activity › Forums › Boris FX Particle Illusion › PI and Sony Vegas
  • PI and Sony Vegas
    Posted by Ken Karn on October 20, 2005 at 9:23 am
    HI!
    I’m kind of “turned-around here” after trying to figure this out for too long.
    I’ll go from Vegas with a rendered avi clip into PI, then back again.
    My new PI’d clip is a slightly smaller image than the original (in the neighboring track, on the timeline).
    The PI’d image is surrounded by a thin black frame, within the frame.
    It looks like I’m “zoomed out” when rendered in PI.
    It seems I’m missing something “basic”, here.
    Any “takers”?
    Thanx a ton–
    Ken
    Elvis Deane replied 20 years, 11 months ago 2 Members · 1 Reply
  • Elvis Deane
    October 20, 2005 at 6:10 pm
    What are your project settings in Vegas before you export? This is a bit of a guess, but if it’s a DV or broadcast project, then the pixel aspect ratio would be set to 0.9. Since pI only writes square pixels, the pIed clip may end up being wider than the Vegas project settings.
    So the solution would be to go into the clip’s Properties in Vegas and change the pixel aspect ratio, or export the clip from Vegas with square pixels in the future before you do any pI work on it.
    Elvis Deane!
    The particleIllusion FAQ
    particleIllusion Resources and tutorial CD
    Astounding Adventures
