Activity Forums Boris FX Particle Illusion PI AE questions
  • PI AE questions
    Posted by Peppe Tannemyr on April 8, 2013 at 1:47 pm
    Just purchased AE version, feeling a little bad since you can´t draw curves for the emitters ( or have anyone a hint here?) also the missing of deflectors , will this be later on or is it just impossible to do?
    I have used 3.0 for a long time and noticed in AE version I can use canvases up to 5400×1080 f.ex,in
    3.0 1920×1080 is the limit. That´s my choice to also buy AE version, but missing curves was a big downer.
    Alan Lorence replied 13 years, 4 months ago 2 Members · 3 Replies
  • Alan Lorence
    April 12, 2013 at 2:14 pm
    There is no way to get a curved line emitter (which I think is what you’re asking about). Also, deflectors are not in there, and probably won’t be added — sorry to say.
    Why do you think pI3 has a limit of 1920×1080? You can render almost any stage size you want — just type the width and height values you need.
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
    http://www.genarts.com
    http://www.wondertouch.com
  • Peppe Tannemyr
    April 12, 2013 at 8:33 pm
    Hi, Thanks for replying!
    I do miss the functions you have in PI,most are gone in PI AE, but I understand that they are two
    different version of course, deflectors..hmm. to bad ( hade a hope that it was maybe coming)
    Alt+click on position in PI gives a bezier curve on a position key, in AE version not,
    Maybe I miss something here…..?
    About the resolution, I´m on mac and when I type in a big,big resolution, the output seems limited to
    1920×1080 as max, never get the render result bigger then that….hmmmm, need to get closer to this again as you say it will work.
    I do really like PI, such a great and fast application, would not make my work without it….
    Really hope that it is not just parked as “ready and done”…
  • Alan Lorence
    April 15, 2013 at 2:22 pm
    Once you’re in AE, you use AE’s UI conventions. So however you normally create a curve in AE is how you do it in pIAE too — alt-click only works in the standalone version of pI.
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
