Activity › Forums › Boris FX Particle Illusion › PI 3 Freezes trying to open an emitter library
  • Alan Lorence
    April 29, 2013 at 2:14 pm
    Check your Library Backups folder, and try loading an older version of that same file. If it used to load fine, some change you made probably corrupted it. I’d start with the most recent backup and go backward from there. Once you find one that loads, I’d be interested to hear what you changed since then.
    Also, what exact version of pI3 are you using?
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
    http://www.genarts.com
    http://www.wondertouch.com
  • Terry Mitchell
    April 29, 2013 at 4:01 pm
    Version 3.0.4.3
    Loaded a previous backup and it worked.
    I have no idea what changes I made to cause the later version of the file to crash the program.
  • Alan Lorence
    April 29, 2013 at 4:36 pm
    Are the two versions much different in size?
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
  • Terry Mitchell
    April 29, 2013 at 5:45 pm
    The older one that works is 88,034 kb and the one that doesn’t is 90,877 kb. I obviously added some emitters (extracted from some of the free downloads), but I don’t know which ones.
