Activity Forums Panasonic Cameras physically label P2 cards
  • physically label P2 cards
    Posted by Craig Alan on March 1, 2014 at 9:14 pm
    I have been using p-touch labels with good results. But our current work-flow requires frequent dumping to computers and reformatting and I need to label and erase the white back of the cards. I tried a permanent marker and it applying was fine but it took a bit of effort and an alcohol wipe to get the ink off. Is this the best choice or would another marker type work better? I was a little concerned that frequent use of alcohol would wear the shiny surface of the white square on the P2 cards.
    It might have been that the marker I used was a little on the dry side not being a new marker.
    I’ve heard dry erase mentioned but am concerned that that ink tends to smear easily.
    Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
    Craig Alan replied 12 years, 5 months ago 2 Members · 3 Replies
  • Joel Freedman
    March 1, 2014 at 11:41 pm
    The white space is basically a time dry erase board. You can use a marker like a sharpie, then write over the Sharpie with a Dry Erase marker and immediately wipe of with soft cloth.
    Joel Freedman
    http://www.2hungrydogs.com
    twitter.com/2HungryDogs
  • Craig Alan
    March 2, 2014 at 1:57 am
    So a dry erase marker will help dissolve the “permanent” ink? Alcohol does the trick too but may destroy the finish of the white board?
  • Craig Alan
    March 8, 2014 at 2:19 pm
    Thanks – works like a charm. Got a set of very thin permanent markers and a thick dry erase marker and all is good.
