Activity › Forums › Maxon Cinema 4D › physical sky problems
  • physical sky problems
    Posted by Ekpeti Chuks on November 16, 2017 at 9:03 am
    hi everyone
    please am having challenge here with the physical sky in my project scene. its a daylight scene am working on and although its a complex scene with so many objects on the scene and lots of camera movements as well. when i render out the project scene, at some point the physical sky turns night as the camera moves, which is strange because i have not activated the night time on the physical sky, i have check and there are no keyframes changing day light to night time and the camera is not entering inside any object on the scene as well. i have had this same problem before but when i change the camera position it became fine. but this time around i really dont want to make much changes on the camera position as it will not work well with scene. please has anyone experience this before and what was your solution to the problem. this is really annoying for me because i cant find out until i have rendered the scene, which is really time consuming, and i have very little time to deliver on this job.
    thanks in advance as i await ur helpful suggestions.
    chuks
    Ekpeti Chuks replied 8 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
