Activity › Forums › Apple Final Cut Pro Legacy › Physical Dimensions of a SD 480i Project
  • Physical Dimensions of a SD 480i Project
    Posted by Kat Hayes on December 21, 2007 at 12:28 am
    I want to import still images into a SD 480 FCP project. I might do some zooms on parts of the pictures.
    1. What is the native resolution/physical dimensions of video or images that are included in the timeline?
    2. How much bigger should I make the ones that I will zoom on?
    Thanks in advance.
    Richard Harrington replied 18 years, 9 months ago 3 Members · 3 Replies
  • Richard Harrington
    December 21, 2007 at 12:31 am
    720 X 480 nonsquare pixels
    Suggest you start with my book and podcast…
    Your question is VERY deep answer…
    Watch this… then go deeper
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
  • David Battistella
    December 21, 2007 at 4:01 am
    A general rule.
    An image double the frame size 1440x 960 with the same dimensions as your source will let you zoom in to about 150% to 175% quite easily.
    A maximum of 150 DPI but 72 DPI is enough.
    DO not make the common mistake of using high DPI files (it does not make a difference but it forces FCP to do far more calculating than it has to.
    David
    December 21, 2007 at 4:54 am
    DPI means Dots Per Inch (IN PRINT)
    PPI means Pixels per inch.. which is how graphics are measure
    Inches means nothing in the world of video as the same signal goes to screens of all sizes
    DPI/PPI mean NOTHING to video..
    Total pixel count
    I STRONGLY suggest going to the Photoshop forum.. researching several posts…
    subscribe to teh free podcast… and pick up the book Photoshop for Video…. It has helped A LOT of people.
