Activity › Forums › Adobe Photoshop › Photoshop vs. After Effects Color Problem
  • Photoshop vs. After Effects Color Problem
    Posted by Toosday on September 8, 2005 at 6:59 pm
    Hi. I took an Adobe Photoshopo CS2 file into After Effects 6.5 Pro and rendered a movie out of it. (After it was animated, of course.) I did this so that I can create a transition in DVD Studio Pro. However, the colors in Photoshop and After Effects are slightly different (one is slightly lighter). I made sure they are both RGB. Is there anything I can do to fix this problem? Thanks!
    Richard Harrington replied 21 years ago 2 Members · 3 Replies
  • Richard Harrington
    September 8, 2005 at 10:53 pm
    Turn off Color Management in your PS color settings menu
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
    September 8, 2005 at 10:59 pm
