Activity Forums Adobe Photoshop photoshop to indesign?
  • photoshop to indesign?
    Posted by Dabbleby on December 17, 2005 at 7:07 pm
    i’m having troubles transfering images that are not a square or rectangle into indesign. it shows up in indesign with a white box around it no matter what I try to do. how can i fix that?
    whoopie
    Kim Mackenzie replied 20 years, 9 months ago 2 Members · 1 Reply
  • Kim Mackenzie
    December 17, 2005 at 8:35 pm
    Indesign should recognize Photoshop transparency.
    It’s probably your Display settings – InDesign is showing you a rough preview of the Photoshop file to save screen redraw time so your machine will run faster.
    In InDesign, go to the View menu > Display Performance > and switch it to High Quality Display.
    You can also change the display quality for a single object by right-clicking or control clicking on the object and setting it in the popup menu.
