Activity › Forums › Apple Final Cut Pro Legacy › Photoshop to FCP
  • Photoshop to FCP
    Posted by Joseph Mclachlan on August 17, 2006 at 8:26 am
    Hello,
    I have been using images at 300 dpi for my TV slideshows (is this unecessary?)and now I am lost as to what the best scanning resolution is for video slideshows. I have used the preset: PAL D1/DV 720 x 526 (with guides), and using the copy and paste, I’ve imported an image that was 300 dpi. Sure enough it was giant when I pasted into the new document with guides, at 72.
    Any attempt to change the 72 dpi and the preset becomes a cutom preset and I loose the guides. Does this mean that for TV you only need image to be 72 dpi?
    The method I have been using from start to finish is as follows:
    1. Scan photo at 300dpi
    2. Save image as a jpeg then crop and lighten till satisfied
    3. Import into Final Cut Pro and add transitions
    4. Export FCP file to Compressor and Compress file
    I’d like to be in complete control and know what I will be able to view, at the best resolution, without any unwanted cropping or distortion.
    I also use a projector to display the slideshow and wondered if I need to take that into consideration as regards best resolution for the final output? (TV or Projector)
    Please forgive me, I’m from a print background.
    If you could please help that would be much appreciated
    Thanking you,
    Joseph
    17″ PowerBook G4, OS 10.4.6, Final Cut Studio, Photoshop CS2, Canopus ADVC110
    Richard Harrington replied 20 years, 1 month ago 2 Members · 3 Replies
  • Richard Harrington
    August 17, 2006 at 1:06 pm
    Short Version
  • Joseph Mclachlan
    August 18, 2006 at 9:58 am
    Thank you Richard.
    I will take your advice on board and endevour to sharpen and hone my skills with FCP and photoshop.
    Hopefully I can get it right, reduce file size and speed up production.
    Pointing me to your tutorials and blog will be of great value.
    Thanks again
    Love the COW!!!
    Joseph
    August 18, 2006 at 3:40 pm
    Good luck
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors, Understanding Adobe Photoshop, and ATS:iWork
