Activity › Forums › Apple Final Cut Pro Legacy › Photoshop title jump
Posted by Bob Cole on May 15, 2007 at 6:40 pmI tried to use Photoshop for title generation but noticed that at transitions, even after rendering, the graphic jumps a bit. When I double-click I get another timeline with the PSD layers; when I double-click the text layer in that timeline, I finally get to see the Photoshop layer in the Viewer, and the file is offset from the center a bit. I thought I had the correct pixel dimensions — any insights?
— Bob C
Bill Lee replied 19 years, 4 months ago 3 Members · 13 Replies -
Jeremy Garchow
May 15, 2007 at 7:00 pmPhotoshop works in square pixels and SD NTSC does not. You need to work in square pixels in photoshop (720×540) then at the very last step unconstrain proportions and change size to 720×486 (or 480 if working in dv).
The other thing is to make sure the the full option is checked under Sequence > Render all and sequence > render selection. Once you have put a check next to the full options, hit option-r to render all.
Jeremy
Bill Lee
May 16, 2007 at 3:45 amThis was the old method of using Photoshop.
As of Photoshop CS onwards, you can select non-square pixels as the Preset for a new document. This means that you can work with 720 x 480 NTSC (DV) or 720 x 486 NTSC (D1) frame sizes with Pixel Aspect ratios of other than 1:1. They even have frame sizes for anamorphic 16:9 video.
This means that the process of round-tripping between FCP and Photoshop is vastly improved, since you leave the frame size constant and work with non-square pixels when drawing. You can toggle the display between non-square and square pixels in Photoshop with View>Pixel Aspect Ratio Correction.
Bill Lee
Jeremy Garchow
May 16, 2007 at 4:46 am[billlee] “This was the old method of using Photoshop.”
i hear ya, but he didn’t say what version of Photoshop, and in CS I thought it was just a display not a design issue. The display allows you to toggle, but it warns you it’s for display purposes only. Am I wrong about that?
Jeremy
Bob Cole
May 16, 2007 at 4:56 amPlot thickens, or I’m feeling even denser.
1. 720×540 .psd, imported straight into FCP. No pixel shift. But FCP automatically repositioned (centered?) the graphic for me. In the all-important y-axis the repositioning (revealed in the Motion tab) was in full pixels. Result: the graphic stays put during the dissolve.
2. I resized the same graphic above to 720×486. On the dissolve out from the graphic, there is tearing — repeated pixels at the bottom of the fonts. FCP had again automatically centered the positioning, but this time 14.5 pixels vertically. When I changed this to 14 pixels even, the tearing disappeared but there is still a little jump on the dissolve from graphic to live action.
I must be missing something here. Version 2 should’ve been better than 1. Why is FCP recentering the graphic? Why the inconsistent results with that persistent jump?
Bob Cole
May 16, 2007 at 5:00 am[JeremyG] “he didn’t say what version of Photoshop,”
sorry about that — CS.
Bill Lee
May 16, 2007 at 5:41 amJeremy “The display allows you to toggle, but it warns you it’s for display purposes only.”
The message that Photoshop CS 2 gives you is “Pixel aspect ratio correction is for preview purposes only. Turn it off for maximum image quality.”
I think this is there just to warn you that you are not dealing with square pixels, and that there may be round off errors with some wierd aspect ratios in displaying an image or selecting pixels. The advantages IMHO greatly outweigh any possible disadvantages with not having to rescale images multiple times if you are round-tripping between Photoshop and FCP. The only area which I don’t know whether it handles the non-square pixels correctly is in filters that use radii of effect, such as the Gaussian Blur: when applied to an anamorphic image, it should give an effect which is circular instead of oval-shaped. I don’t know if it actually does or not.For so many years of Photoshop, all pixels were square and now you can set them to an anamorphic ratio. When you have the pixel aspect ratio turned on, you can now get guaranteed circles using the Eliptical marquee tool in conjunction with the Shift key without later having to rescale. A pencil tools one pixel square looks rectangular onscreen, but is actually one pixel wide and high. In essence, that’s why Adobe made these presets available: to be used to edit frames for video.
If you look in the help for Photoshop CS 2, it has the following information:
“To help you create images for video, Photoshop has a Pixel Aspect Ratio Correction viewing mode that displays your image at a specific aspect ratio. For more accurate previews, Photoshop also has a Video Preview command that lets you immediately preview your document on a display device, such as a video monitor. To use this feature, you must have the device connected to your computer via FireWire. See also ‘To preview your document on a video monitor’.”Bill Lee
Bill Lee
May 16, 2007 at 6:27 amWhen you import still pictures into FCP, it looks at the sizes of the images you are importing and makes some decisions based on those sizes. On images that it thinks are standard video images, it will set the pixel aspect ratio to one of: Square, NTSC – CCIR 601, PAL – CCIR 601, HDV (960×720), HD (1280×1080). If you are just one pixel out, it will default to square pixels.
Example: Importing an image 720 x 487 will import that image with a square pixel aspect ratio, whereas an image 720 x 486 will be imported as NTSC – CCIR 601.
When you drag such an image into your timeline, the image will be scaled if it is larger than the frame size. An example of this is that an image 721 x 487 was scaled to 99.86% to make the largest dimension (x or y) fit into the frame. Images smaller than frame size will not be scaled to fit.
If your sequence is 720 x 480 DV, then your pictures should also be 720 x 480 instead of 720 x 486 D1. Otherwise, set the scale to 100% and let the three extra pixels hang off the top and bottom of your frame. Likewise, if your sequence is D1, your pictures should be D1 (720 x 486), otherwise you will get a three pixel black line top and bottom of the frame (immaterial for TV, bad for web delivery).
So as to your situation, did you scale the picture in Photoshop, or in FCP? I can’t remember running up against it automatically offsetting an image before, since the default position of images and video is at (0,0) which is the centre of the frame.
If you change the pixel aspect ratio of some clip in the timeline, then you have to replace it with another copy of that (modified aspect ratio) clip from the browser, since it won’t visibly change aspect ratio once it is in the timeline.
Bill Lee
Bob Cole
May 16, 2007 at 2:32 pmThis has turned into more of a puzzle than I’d thought. Doing the wrong thing works, and vice versa. Surely I must be doing something very basically wrong here.
1. In PS CS, I created 720×540 graphic. White (235/230/230) text over black background. Imported to FCP 720×486 timeline, the red line immediately appeared. I dissolved from graphic to live action, and rendered. Result: no jumps.
2. In PS CS, I non-proportionally changed the pixel dimensions of that same graphic to 720×486. In FCP, no rendering line. But two problems: (a) long vertical smear (faint but definite) at the right side of the last letter and (b) from the very first frame of the dissolve out to live action, the text jumps slightly larger, particularly in the vertical dimension. Putting a darker color on the font makes the smear even fainter but the dissolve still makes the text jump.
re: my earlier centering question: I was thinking that may be due to how I made the graphic inside PS, but it’s still inconsistent. For Graphic #1 (720×540) above: When I double-click the graphic to pop up its own timeline, and then double-click each layer, the black background layer is centered at 0, 0, while the text layer is centered at 4.5, -16. For Graphic #2 (720×486): 4.5, -14.5. That half-pixel makes the dissolve-jump especially troublesome, as it creates a doubling-up of the lower part of the font. When I change that to 4.5, -14, the moire effect disappears but the dissolve jump remains.
Thanks for wading through this tedious and annoying problem. Any insights would be most welcome. Or should I just wait for FCP Studio 2?
— Bob C
