Activity Forums Apple Motion Photoshop Text Effects Not working in Motion 3
  • Photoshop Text Effects Not working in Motion 3
    Posted by Frank Philip on November 15, 2009 at 5:33 pm
    I’m trying to import text layers with effects from Photoshop CS2 into Motion 3, but none of the effects aren’t working. Such as a title with the fill completely removed while adding a white stroke.
    I’ve even added flourish type of brushes that were originally black but made an effect change to an off white. Yes, I know I can change the master one first but trying to get Motion to see the “effects”.
    I already tried rasterizing the brushes and text and nothing seems to work.
    Any ideas why this is happening?
    Thx
    Eyal Shtark replied 16 years, 10 months ago 3 Members · 3 Replies
  • Frank Philip
    November 15, 2009 at 6:06 pm
    I figured it out. I dragged every layer that has text effects or layer effects on brushes from the PSD file from within Photoshop (individually) onto a new document and merged layers while maintaining transparency. Then I dragged it back into my composite and deleted the original layer with effects.
    I hope this helps someone!
    http://www.greenirisstudios.com
  • Noah Kadner
    November 15, 2009 at 8:03 pm
    Yeah any sort of Photoshop effects generally need to be rendered or rasterized in Photshop, before dragging into motion. It basically imports the alpha channel and the layers, but not much in the way of Photoshop native effects.
    Noah
    Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera! Unlock the secrets of 24p, HD and Final Cut Studio.
    Call Box Training now featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II, Canon 7D, and Panasonic DVX100.
  • Eyal Shtark
    November 15, 2009 at 9:57 pm
    If you want to keep the photoshop file editable then just convert the text layers into smart objects.
    in this way your files will look fine in motion and you can always go back into photoshop to edit them.
    Eyal.
    Eyal Shtark
    Exhibitions and Multi-Media
    Team Leader
    Advertising department
    ISCAR LTD.
    Tel. +972-4-9970371
    Fax. +972-4-9970422
    Email: eyal@iscar.co.il
