Activity Forums Adobe Photoshop Photoshop: Showing description
  • Photoshop: Showing description
    Posted by Ben Albright on December 6, 2014 at 10:34 am
    In Photoshop CS5, I have it set to print at 25% size with the file description under it. The problem is I don’t want to print. I want to just see it in front of me, and take a screenshot. I don’t really know how else to explain it, but I know if I save it as a pdf, there’s a way I can see the description, but I don’t know how to get it to show up.
    Joel Bellagamba replied 11 years, 7 months ago 3 Members · 6 Replies
  • Todd Perchert
    December 8, 2014 at 3:31 pm
    When you select to Print, a dialog box should come up. Inside that box should be Print Settings. If you go there you should be able to select to print (save) to a PDF.
    Good Luck!
    TC
  • Ben Albright
    December 9, 2014 at 1:38 pm
    Todd, I don’t see that option anywhere. This is what I get when I click “print settings”. “PDF” isn’t listed anywhere under these tabs.
  • Todd Perchert
    December 9, 2014 at 5:22 pm
    Ah! Windows. Do you have Adobe Acrobat installed? If so, when you go to print you should have the option to select print devices – don’t select your printer, select Adobe PDF. If you don’t have Acrobat, get it, install it.
    Good Luck!
    TC
  • Ben Albright
    December 9, 2014 at 11:53 pm
    Alright, thanks. I’m not paying $100 dollars just to have that feature, so I guess I’ll have to do it manually.
  • Todd Perchert
    December 11, 2014 at 5:21 pm
    I believe you only need the free Acrobat Reader, but I could be wrong.
  • Joel Bellagamba
    January 31, 2015 at 9:28 am
    Can you upload a screen shot of your setting, what you actually want?
