Activity Forums Adobe Photoshop photoshop settings for importing into premiere
  • photoshop settings for importing into premiere
    Posted by Joe Bandy on November 19, 2008 at 11:33 pm
    Question:
    For an Adobe premiere project using 720 x 486 pixel 0.9. If I want to bring in a Tiff from photoshop used for titles what project setting do I need to use in photoshop.
    I am using photoshop CS3 extended and premiere pro cs3.
    All the titles I have tried to bring in have looked very blocky and it looks like some lines of resolution are smaller in the text.
    Ronaldo Montalvo replied 17 years, 9 months ago 2 Members · 1 Reply
  • Ronaldo Montalvo
    November 20, 2008 at 5:45 pm
    up to now i have always built graphics for D1 in photoshop using a square pixel 720×540 layout and then let premier scale it to 720×486 non-square. you can also build your pshop graphics at 720×540 square and then save a second version that you non-proportionally change to 720×486 and import that into premier. it adds a second step/version of each picture but works fine.
    i’ve recently seen some info about the new pixel aspect ratio that CS4 uses which is apparently .91 rather than .9, which means a square pixel comp D1 should be 720×534. here’s a tutorial that talks about it:
    https://movielibrary.lynda.com/html/player/index.cfm?id={50AEFD66-0E51-4246-9660-4D44F53A490E}&redirect=no
