Activity Forums Adobe Photoshop Photoshop scripting help
  • Photoshop scripting help
    Posted by Rob Stemm on January 17, 2008 at 6:40 pm
    I have a PARAGRAPHTEXT text box in Photoshop that I plan on populating with text using .jsx scripting. One thing I need to do is to center the text box vertically between two y values and save a final image. Is there anyway for the script to determine if the text has wrapped to the second line in the PARAGRAPHTEXT text box? If I know there are two lines of text the y value will be different than if there is only one line of text.
    Thanks for any advice,
    Rob
    Rob Stemm replied 18 years, 7 months ago 2 Members · 2 Replies
  • Ekim Wahs
    January 17, 2008 at 9:44 pm
    try using
    var x = app.activeDocument.activeLayer.bounds
    //returns array of left side , top, right side, bottom
    alert(“bottom = “+x[3])
    Mike Shaw
    Photoshop QE
  • Rob Stemm
    January 18, 2008 at 2:01 am
    That did the work. Thanks for your help!
    Rob
