Activity Forums Adobe Photoshop Photoshop Pixel Aspect Ratio quesion…
  • Photoshop Pixel Aspect Ratio quesion…
    Posted by Jason Brown on January 17, 2006 at 5:16 pm
    Hey All,
    Just curious, I am using PS 7.0 and use it for video work quite often. So when I create a document for TV specs, I do 720 x 540 (square pixels). But I know that in the new CS version, you can do non-square (rectangular) pixels.
    My question is, how does photoshop 7 interpret a document made with non-square pixels? Does it have the same pixel count, and just make them square? Or does it take into account the PAR and make however many square pixels it needs?
    Thanks in advance…
    -Jason
    P.S. Also, completely off topic here…is CS considered a version above PS 7.0? Are there things you can do in PS7 that you can’t do in PS-CS?
    Richard Harrington replied 20 years, 8 months ago 3 Members · 2 Replies
  • Dan Archer
    January 18, 2006 at 10:15 pm
    Jason Iuse PS for video everyday. As far as i know PS7 does not have any pixel magic for 720 x540 images.
    I always design in 720×540 and right before I save I resize to 720×486.This will keep your round stuff round. I also work these graphics in an AVid. It also has dialouge for resizing images on import. I use these too if i am in a hurry. Hope this helps.
  • Richard Harrington
    January 22, 2006 at 6:18 pm
    Better to resize in PS…. cleaner that Avids scaling algorithim
    PS 7 incorrectly distorts a graphic opened with nonsquare pixels and displays it wrong.
    All the command does in CS or CS2 is adjust onscreen preview.. pixels are still squished (as they should)
    You can see more at Photoshopforvideo.com
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
