Activity Forums Adobe Photoshop Photoshop Mask problem
  • Photoshop Mask problem
    Posted by Brian Evancic on January 19, 2011 at 5:39 pm
    I have two images stacked on top of one another and applied a layer mask to the top layer so I can mask out a section to show the bottom layer. I’ve done this a hundred times but for some reason now when I paint black on my mask it’s not revealing all of the layer underneath. It’s transparent. My blending mode is on normal, flow and opacity are 100%. I’m at a loss. Any suggestions?
    Scott Roberts replied 15 years, 7 months ago 2 Members · 1 Reply
  • Scott Roberts
    January 23, 2011 at 11:21 pm
    Sounds like you’re doing everything right. Did you accidentally select inverse? Are you painting/filling with white accidentally? Is your airbrush set to normal? Start a new document and try again from scratch and see if the problem occurs again.
    https://www.graphicsdump.com
