Activity › Forums › Adobe After Effects › Photoshop Live 3D Motion Blur
Posted by James Murphy on March 15, 2011 at 6:29 pmIs there a way to add motion blur to Photoshop Live 3D text animated in After Effects? The traditional method seems not to work.
Kevin Camp replied 15 years, 5 months ago 2 Members · 2 Replies -
Kevin Camp
March 15, 2011 at 6:48 pmcc force motion blur.
first try applying it to the 3d layer itself, but you may need to apply it to an adjustment layer above the 3d layer… this of course means that you are applying the effect to all layers bellow it, and that can have a pretty severe impact on performance. the workaround for that would be precomping the 3d layer and the adjustment layer.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Kevin Camp
March 15, 2011 at 6:52 pmi should note that the precomping method would only work if the layer itself was animated, not if the camera was animated…
also, if the movement is pretty simple (say the object moves across the screen, or a simple rotation), then you could try something like directional blur, which would render significantly faster.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
