Activity › Forums › Adobe Premiere Pro › photoshop layers and premiere pro
  • photoshop layers and premiere pro
    Posted by Kerry Baldry on July 31, 2017 at 10:39 am
    Hi, I am trying to import photoshop cc layers to premiere pro cc (2017)
    but once imported into premiere pro the images turn to black.
    jpegs etc are all ok.
    Kerry Baldry replied 9 years, 1 month ago 3 Members · 4 Replies
  • Jon Doughtie
    July 31, 2017 at 8:41 pm
    Do you have any Photoshop effects applied to any layers? I don’t believe those will translate in Premiere Pro.
    Do you have any layers/elements/files that are not 8-bit RGB? If you have, for example, and elements with a CMYK colorspace, they won’t make the transition.
    These are the first two things I would check.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2015.02 (as of 6/2016)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
  • Kerry Baldry
    August 1, 2017 at 6:45 am
    Hi, thanks i checked – the image is 8 bit and RGB. There are no effects applied to layers. Still comes out
    black in premiere..
  • Ann Bens
    August 1, 2017 at 7:50 pm
    What are your sequence settings and what are the dimensions of this psd file?
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • Kerry Baldry
    August 2, 2017 at 8:15 am
    Hi
    When I go into premiere pro cc
    into New: New photoshop file
    a file with the same settings (whatever settings i have chosen) is automatically
    made in photoshop. However the although the two are linked the image in premiere pro is black.
