Activity › Forums › Adobe After Effects › Photoshop layer imports at “wrong” scale
  • Photoshop layer imports at “wrong” scale
    Posted by Stuart Samuels on October 11, 2012 at 10:50 am
    Hi.
    I am working on a project that requires some small background items painting out.
    I export the frame from AE (composition -> save frame as), open the frame in PS, fix the area I need to on a new layer and save the file, import the fixed PSD file as footage, but when I drag it into the comp it is 1/4 the size it “should” be.
    I put the word should in inverted commas because clearly I am doing something wrong. I have done this type of job many times before and I’m sure I’m just making a simple mistake but despite trying I just can’t figure out where I’m going wrong.
    Can anybody help me out?
    Stuart.
    John Cuevas replied 13 years, 9 months ago 3 Members · 4 Replies
  • John Cuevas
    October 11, 2012 at 3:24 pm
    When you > Save Frame As is your composition at Best Quality and Full Size?
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Vishesh Arora
    October 12, 2012 at 8:27 am
    Stuart
    you can save the frame in two different ways:
    1. Save Frame As> File
    2. Save Frame As> Photoshop Layers
    When you choose file, you can manipulate the export settings like resolution, compression etc as it will render out through Render Queue.
    Check your Render setting and output Module whether you are using right settings or not.
    the Second way will render the file as Photoshop layers with the default settings of Composition.
    Vishesh Arora
    VFX and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    Demo Reel(3D):
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Stuart Samuels
    October 12, 2012 at 9:17 am
    Thank you.
    I must have changed a setting somewhere along the way.
    Much appreciated.
  • John Cuevas
    December 11, 2012 at 12:23 pm
    Glad I could help out.
    Thinkck.com
