Activity Forums Adobe Photoshop Photoshop Inverted Mask size difference
  • Photoshop Inverted Mask size difference
    Posted by Iris Moleman on June 30, 2014 at 9:41 am
    Hello all,
    I’ve got a problem with Inverting masks in photoshop. If I invert a mask, the new mask is a bit smaller than the original mask.
    If my layers are two identical images with a mask applied to one layer and the inverted mask applied to the other layer, I’d expect to see the whole picture. But there is a small empty ‘edge’ around the mask-shape.
    I can’t explain it really well, but i hope this screenshot will make it clear. There’s a small edge around her face.
    I set all the refine-edge and feather options to 0, so that can’t be the problem I guess.
    I also found out the problem isn’t the inverting itself; If I duplicate the mask to another layer without inverting it, the duplicated Mask is a bit bigger than the original mask.
    Who can help me?
    Thanks in advance!
    Iris
    Iris Moleman replied 12 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
