Activity Forums Adobe After Effects Photoshop import has Missing Frames
  • Photoshop import has Missing Frames
    Posted by Shuling Yong on April 4, 2010 at 8:50 pm
    Hi folks,
    I’m using AE CS4. When I import a .psd file, I get the error message “After Effects warning: The sequence has 1 missing frames (39:44)”. The message keeps popping up multiple times, and i think it has to do with the number of layers i have in that file.
    I’ve imported that file with no issues in the same project in the past, so I’m confused why it’s telling me this now. How does a photoshop image have a certain number of frames when it’s just a single image? What can I do to solve this issue?
    Thank you!
    Cheers,
    Shuling
    Ian Berg replied 16 years ago 3 Members · 2 Replies
  • Roland R. kahlenberg
    April 5, 2010 at 6:32 am
    Never had such issues. Try using another file format. Also, take a look at your prefs to see if PSD files are set to import as sequenced images.
    You may also want to visit old COW hand athttps://blog.myleniumstuff.de/. Once there, click on the link for AE Error Codes and see if that’s helpful.
    Cheers
    RoRK
    Sell your AEPs with broadcastGEMs’ DVD series of templates. Click here for more
  • Ian Berg
    August 7, 2010 at 9:52 pm
    I had this same difficulty… I opened the .psd in photoshop and re-saved it using a different name and then imported it into AE. It worked fine… I am assuming the AE project must have thought the file was already imported and this confused it… try it and if it works.. awesome 🙂
    Ian
