Activity › Forums › Apple Final Cut Pro Legacy › Photoshop import gives me strange lines
  • Photoshop import gives me strange lines
    Posted by David Rowan on September 20, 2005 at 6:01 am
    I’ve made a fancy little box in Photoshop. In FCP I fly the two layers together over video, then I add a font on top. Pretty standard stuff. The graphic is saved as a PSD so I can bring in the layers separately.
    Before I render everything looks fine. After I render there are very thin green and pink lines adjacent to my little graphic. The lines are visible on both the computer screen and the NTSC video monitor. I tried different backgrounds and different positions on the screen, but to no avail.
    The timeline is Uncompressed 10 bit 4:2:2. The graphic was created with the Photoshop 720X480 template.
    What am I doing wrong?
    DWR
    Joe Murray replied 20 years, 11 months ago 4 Members · 5 Replies
  • Bouncing Account needs new email address
    September 20, 2005 at 11:08 am
    What colors are you using in the graphic?
  • David Rowan
    September 20, 2005 at 2:03 pm
    a mild pinkish red and beige. Nothing very saturated.
    DWR
  • Bryan Keith
    September 20, 2005 at 7:03 pm
    its a bug that has been there a while. Try saving the files as tiff’s as opposed to psd’s. That should do the trick.
  • David Rowan
    September 20, 2005 at 11:01 pm
    Worked around the problem. Here’s what I did (in case anyone finds this in a search)
    Instead of using Photoshop’s NTSC 720X480 template I just made my own 4 inches by 3 inches at 300DPI project. Yeah, I know, its more pixels than necissary.
    But it worked. Graphics made at this scale did not have the thin line artifacts.
    DWR
  • Joe Murray
    November 4, 2005 at 2:19 am
    I know this thread is a bit old, but I have a question…did you compare render times between the old artifact-ed Photoshop file and the 300 dpi version?
    Just curious-
    Joe Murray
