Activity Forums Apple Final Cut Pro Legacy photoshop graphics in fcp
  • photoshop graphics in fcp
    Posted by Arty Gold on September 28, 2005 at 2:07 pm
    does anyone know, or has this happened to anyone ?
    i made a lower third graphic in photoshop…
    got it already the way it needed to be…however…in fcp the color looks off and faded…
    anyway to fix this ?
    Kevin Monahan replied 20 years, 12 months ago 4 Members · 5 Replies
  • Bouncing Account needs new email address
    September 28, 2005 at 2:15 pm
    You must only judge IMAGE QUALITY and color in FCP on an EXTERNAL video monitor (not on the computer screen).
    If you created your Photoshop image on an LCD monitor, it can look very different on an external video monitor.
    You must learn to compensate for this when you create in Photoshop.
    If you have certain video cards (such as PipePro and Kona) for use with FCP, they can actually output your Photoshop computer image as you work, so you can judge it properly for video.
  • Arty Gold
    September 28, 2005 at 3:26 pm
    great…thanks…
    it looks great on my computer screen,,,it;s the external monitor where it looks wacky…
    but what you are saying is i just have to justify the colors by hand or by eye till i get it right !
  • David Rowan
    September 28, 2005 at 5:00 pm
    I just got my own system, and since I only have one Apple display I got the DVI to Video adapter and plugged that into the second monitor output. Now my NTSC monitor is my second computer screen, and when I work in photoshop I can drag the images over and quickly check them for how they look on TV.
    I haven’t done it yet (since I only hooked it up last night), but I also plan on using it to check the DVD preview in DVD studio pro, as well as a way to see what I’m doing in FCP.
    At the TV station where I work we have Kona cards for the Macs in the Art Department, and they run everything out to the system and their monitors through the Konas.
    DWR
  • Kevin Monahan
    September 28, 2005 at 5:32 pm
    As wonky as that sounds, yes.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • Kevin Monahan
    September 28, 2005 at 5:34 pm
    You really should monitor video to video monitor via the DV Deck or Kona Card, not the computer if you want to see your colors in YUV colorspace.
    Kevin Monahan
    fcpworld.com
