Activity › Forums › Apple Final Cut Pro Legacy › PhotoShop Graphics in FCP (Studio HD)
  • PhotoShop Graphics in FCP (Studio HD)
    Posted by Jd7373 on September 24, 2007 at 1:23 pm
    It seems each time I import a graphic from PhotoShop into FCP I can see what I can only describe as the ‘box’ around the graphic or the outline of the ‘alpha channel’. Even nesting the graphic doesn’t seem to help. I’ve tried moving the graphic a pixel up or down and sometimes gets a little better, but never really gone.
    (I’m editing in standard def and using the Blackmagic box for Decklink)
    Any suggestions would be greatly appreciated!
    JD
    Jd7373 replied 19 years ago 2 Members · 2 Replies
  • Arnie Schlissel
    September 24, 2007 at 4:01 pm
    Try changing the premultiplication settings & see if that helps.
    Open the graphic in the viewer, type command-9, and find the setting for the alpha. Toggle between straight & premultiplied.
    If that doesn’t help, then post a still from your timeline so we can see what the problem looks like.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Jd7373
    September 24, 2007 at 6:28 pm
    That didn’t fix the problem totally, but it may end up helping out with a couple other issues. As far as posting a screen shot, the issue doesn’t occur until it reaches the preview monitor. It looks fine on my computer and when I export a ‘QuickTime’ movie, etc, but once I cut to tape…ta-da!
    Side note: I see you’re working on a film. I’m part of a weekly ‘movie podcast’ so once you get a trailer up for Peristroika, feel free to contact us and we’ll try to give you a plug. Check it out and see if you’re interested at http://www.moviesfornobodies.com or just send us an email and tell us a little about your project.
    Thanks again.
    JD
