Activity › Forums › Adobe Photoshop › Photoshop for product photo touch up
  • Photoshop for product photo touch up
    Posted by George Loch on November 27, 2005 at 3:12 pm
    I need to change an LCD display on a product photo. The only challenging aspect is that the lcd is laying down. This is one aspect of Photoshop I haven ot explored. What’s the best way to stretch the text to match something at an angle?
    -gl
    George Loch replied 20 years, 9 months ago 3 Members · 3 Replies
  • Renato
    November 27, 2005 at 3:56 pm
    it depends on what version of photoshop you are using… if you have cs2 you can use the new vanishing point filter…
    but if you dont have cs2, you can just rasterize the text (right click on the text layer at the layers pallete and choose rasterize) and then transform it (crtl+t).. during transform, right click on the text and select “distort”… then just drag each corner of the transform box to line up with the corners of the LCD… and it should be in perfect perspective…(sorry, its easier to do it then it is to describe it…)
    just remember that once rasterized the text can no longer be edited…and it will no longer be vector based so scalling it up will make you lose resolution.
    hope it helps, let us know if you have any trouble
    kind regards
    renato
  • Richard Harrington
    November 29, 2005 at 11:34 pm
    WARP Text command…
    Its in the PSCS Book…
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
  • George Loch
    November 30, 2005 at 5:19 pm
    Thanks Richard. I had forgotten about ‘Warp’. It’s a little unwieldy though.
    I am not near my bookshelf. Does your book go over it in detail? I am tryign to apply some lables to a product that is layign semi flat on a surface. Any recommendations?
    -gl
