Activity Forums Adobe After Effects Photoshop Filters in AE
  • Photoshop Filters in AE
    Posted by Michael Goldberg on June 28, 2006 at 9:07 pm
    We’ve used several of the artistic Filters in Photoshop CS2( cutout, underpainting, watercolor, paint daubs etc) for still images. We’re trying to apply these same effects to moving video in AE. I tried copying the filters into AE, but couldn’t get that to work. Anyone have any tricks for getting that to work, or can you suggest a plug in set that is similar. We are trying to avoid outputting hundreds of frames for painting in Photoshop. Thanks for any thoughts.
    Mike
    Fabiano Peres replied 20 years, 2 months ago 3 Members · 2 Replies
  • Mike Clasby
    June 28, 2006 at 11:33 pm
    Short answer – filmstrip (.flm) or image sequence in a folder (and run an action on a the folder PS)
    If you can do it best or you’re more comfortable in Photoshop, then export the video into a form Photoshop can use.
    In AE, with footage in the timeline, Ctrl M, brings up the Render Que.
    Output Module > Custom (Brings up the Output Module Settings Box)
    Format : Select – Filmstrip (my favorite, because it’s a single file and the effect goes on all frames in one shot)
    or select one of the pic sequences (more people use Picture sequences for several good reasons (say a render crashes, you don’t have to start from the beginning, but I’m a bit overwhelmed by all those files generated and running a batch process on them, but that’s just me)
    Import those into Photoshop, filter away, then re-import into AE. Filmstrips re-imported into AE come in as frames
    in the timeline. It’s easier than it sounds.
    The only draw back is that you can’t change the filter setting in PS (like keyframes in AE) unless you break the filmstrip of Image sequence into smaller bits.
  • Fabiano Peres
    June 29, 2006 at 2:21 pm
    Well, this is the way I do it…
    In AE render the movie you want to apply the effect as a JPEG sequence in a folder, then in Photoshop Create an action for the effect you want and apply it to the all of the frames… Take a look at the Andrew Kramer’s tutorial of how to create an action to speed up you work in Photoshop…
    The tutorial shows how to create a slide show, but you just have to learn the part of how to create an action in Photoshop… Instead of resizing, apply the filter you want…
    https://forums.creativecow.net/cgi-bin/new_page_wrapper.cgi?forumid=2&page=https://www.creativecow.net/articles/kramer_andrew/slideshows/index.html
    Then just import it to After Effects again and it’s done.
    I hope it helps you.
