Activity Forums Adobe After Effects Photoshop files in AE
  • Photoshop files in AE
    Posted by Benj Roche on May 4, 2010 at 12:43 am
    I have a layered Photoshop file that I am using to animate a character. His arms, legs, etc are each on a separate layer.
    If I were to add another layer to the PSD file, will it update in AE? If not, will I a simple replace footage work?
    Erik Waluska replied 16 years, 4 months ago 3 Members · 2 Replies
  • Jeffrey Kaplan
    May 4, 2010 at 1:03 am
    You can use the Edit Original command in After Effects to open a PSD file in Photoshop, make and save changes, and have those changes appear immediately in the movie that refers to the PSD source file. Even if you don’t use Edit Original, you can use the Reload Footage command to have After Effects refresh its layers to use the current version of the PSD file.
    Jeff Kaplan
    Point 360 WEST
    Animation & VFX Department
    http://www.point360west.com
  • Erik Waluska
    May 4, 2010 at 1:26 am
    It won’t automatically update and add the new layer. You’ll have to do that manually. Just import that layer only and add it to your comp.
