Activity › Forums › Apple Final Cut Pro Legacy › Photoshop files as sequences
  • Photoshop files as sequences
    Posted by Josh Weiss on March 3, 2006 at 2:50 pm
    It seems that if I take a Photoshop file that was saved on the Mac that final cut is one, it will make a layered sequence for a photoshop file like Final Cut is supposed to. However, from another computer on the network, it will bring in a flat image. Both on PS CS2, however the other computers are PCs so I’m not sure if that has anything to do with it. If I open the files in PS on the mac and resave then it will treat it as a sequence. Any ideas? Is it a PC mac thing or just it has to be from the exact mac with the final cut? Also, is there a way to bring in a PS file as a flat image into final cut if you want to (without flattening it in Photoshop)?
    Debe replied 20 years, 7 months ago 2 Members · 1 Reply
  • Debe
    March 4, 2006 at 12:53 am
    Photoshop on the PC has a different layer structure than Photoshop on a Mac.
    The simplest was to get around it is to open up a PC PSD on the Mac and Save As a PSD.
    That should be enough.
    debe
