Activity › Forums › Adobe Photoshop › photoshop files and premiere pro
  • photoshop files and premiere pro
    Posted by Kerry Baldry on August 4, 2017 at 12:57 pm
    photoshop file black when in premiere pro.
    When I go into premiere pro cc
    into New: New photoshop file
    a file with the same settings (whatever settings i have chosen) is automatically
    made in photoshop.
    However the although the two are linked the image in premiere pro is black.
    Boris Redgard replied 9 years, 1 month ago 3 Members · 7 Replies
  • 7 Replies
  • Steve Bentley
    August 4, 2017 at 4:32 pm
    Does it have an alpha channel? ( in this case it might be black and therefor not letting the RGB pass through and looking black
  • Kerry Baldry
    August 4, 2017 at 6:45 pm
    Hi, yes just checked. it has an alpha channel
  • Steve Bentley
    August 5, 2017 at 1:00 pm
    So you can tell premiere to ignore the alpha and that should do it
  • Kerry Baldry
    August 5, 2017 at 1:39 pm
    thanks.. tried that. still doesnt work.
  • Steve Bentley
    August 5, 2017 at 6:19 pm
    Sorry to here that. Is it perhaps a layered file and premiere is only grabbing the base layer and that is either black or has nothing in it?
    Is it in a color space that premiere can’t do or isn’t set up for (16 or 32 bit)?
    Is it a tiff perhaps that has a mac encoding or vs a PC (same goes for Targas).
    Does it have a compression on it that premeire or your computer cant’t do?
  • Kerry Baldry
    August 6, 2017 at 8:01 am
    thanks, I will try all this
  • Boris Redgard
    August 17, 2017 at 3:01 pm
    Hello! Tell me, what helped you? How did you get rid of the problem with this photo file? It seems that I have the same problem.
