Activity › Forums › Apple Final Cut Pro Legacy › Photoshop Files
Photoshop Files
Posted by Bob Duthaler on July 22, 2010 at 6:37 pmWhat is the best way to bring in a photoshop file in to FCP and keep layers and transparency?
Matt Callac replied 16 years, 2 months ago 4 Members · 7 Replies -
Brian Miller
July 22, 2010 at 6:58 pmWell if you have a psd with all the layers you can just bring it right in. if you put it in the timeline u can double click it to step into the layers just like a nest
Brian Miller
July 22, 2010 at 7:08 pmIn photoshop view only the layer with the drop shadow or glow. Merge visible. Then turn on other layers and resave.
Bob Duthaler
July 22, 2010 at 7:11 pmThanks, we will give it a try. Does it work better to bring in as a transparent PNG file? Are there advantages to either one?
Jeremy Garchow
July 22, 2010 at 7:13 pmWhat Brian says. FCP will not read the PS effects, you have to flatten those first.
Brian Miller
July 22, 2010 at 7:17 pmI have used both ways successfully. If I ask gfx department for pngs its usually b/c they couldn’t get the psd to work right and I’m sick of trying 🙂
Matt Callac
July 22, 2010 at 8:05 pm[Jeremy Garchow] “FCP will not read the PS effects, you have to flatten those first.”
Or you can convert your layers that have layers styles into smart objects in photoshop. In PS right click on the layer and select “convert to smart object”. This way you can import your PS into FCP but it still leaves the Layer editable.
-mattyc
