Activity Forums Adobe After Effects photoshop file not working well with AE
  • photoshop file not working well with AE
    Posted by Larry Watts on April 25, 2006 at 4:11 pm
    I must be missing something obvious here so bear with me.
    I’m importing a photoshop file into AE using the “as a composition” box checked and can’t get them into a composition window in the correct order and correct placement. The objects want to snap to the center point each time.
    I thought I was doing this quite easliy in times past.
    What have I forgotten?
    LW
    Michael Duff replied 20 years, 5 months ago 2 Members · 1 Reply
  • Michael Duff
    April 26, 2006 at 4:36 am
    are you dragging them down from the project window? If so, don’t, open up the comp that came in when you imported the file and then copy/paste them out of there into one of your other comps. I think that will work
    Michael Duff –
    Bearcage Productions, Australia
