Activity › Forums › Adobe After Effects › Photoshop file format error
Posted by Anthony Dupsta on June 26, 2007 at 7:16 pmJust ran into this new problem. I have set a proj to render, half the farm renders this proj and half the farm fails giving me this log. The proj has never produced this error before.
After Effects error: Photoshop file format error 1. (45 :: 35)
I feel this might be a memory issue or possible After effect is trying to render an image sequence that has corrupt frames in the comp?
Does it really have anything to do with PhotoShop?
Any suggestions?Eduardo Pinto replied 14 years, 10 months ago 6 Members · 8 Replies -
Anthony Dupsta
June 27, 2007 at 2:11 amI am still trying to trouble shoot this Photo Shop error.
I am just not sure if this is a memory issue, I am sure spinning my wheels here.
The photo Shop error seems so broad. I am not using any pic files or CMYK color space. Again I’m trying to translate this error, unfortunately it isn’t giving me a place to start. Grrr.Please let me know if you can help me out.
Anthony Dupsta
June 28, 2007 at 4:53 pmAnyone think this might be a memory error and not a photoshop error?
Can’t shake it out.
Anthony Dupsta
June 29, 2007 at 6:19 pmWell I am fired now, no answers, no sleep for the last week. Total melt down.
Guess I will take up lawn bowlingHere is a link to the error that has stumped the COW.
https://img339.imageshack.us/img339/4198/error1wd6.jpg
Jeremy Mayhew
August 22, 2009 at 10:10 pmHaving the same problem today while working on a commercial. Crap.
What is this?!
Mark Ramos
October 6, 2009 at 11:57 amAfter Effects error:
Photoshop file format error (-1).
45 :: 35Not sure if someone has worked it out yet but what i did was change the save setting of the image in Photoshop from bmp to a psd document.
Deleted the previously saved image, reloaded the project then after effects will say that there is 1 missing file, clicked OK then replace the missing link with the new saved image.
It rendered out like a baby 🙂 Hope this helps -
Iouri Verchok
October 10, 2011 at 9:01 amSame thing here. I did nearly half of the project with numerious files imported, where I combine footage and rendered Maya .iff sequences. It worked fine. Then now all of a sudden AE started giving me that crazy ‘After Effects Error: Photoshop file format error 1 (45::35) on all parts, that were working fine. What the heck is that? All my files are intact, nothing’s happened to them. What can start this weird behaviour of AE? Even without it AE is extremely unstable, crashing as if coded by a bunch of shoollboys, but this just drove me crazy. And it seems like no one is answering this question, so is it that really no one knows?
I have Windows 7, AE CS5, Maya 2012 -
Eduardo Pinto
October 19, 2011 at 4:15 amI have to re-render now a project I worked on in january. In that time everything worked out fine, but now…AE keeps giving me this message of Photoshop file format error in all my .iff maya sequences. I don´t have time to render all maya stuff again, there are tons of animations….
In other project i worked on, i removed all color corrections from .iff files and AE rendered out without problems. But the strange thing is that now neither doing this AE accepts to render my .iff maya files. If someone can help, I would be very thankfull.
