Activity Forums Apple Final Cut Pro Legacy Photoshop > FCP
  • Photoshop > FCP
    Posted by Gs2005 on December 21, 2005 at 11:07 pm
    I saved the file in Photoshop as: 729x420x72, constrain properties in unchecked, the save layer box is checked, yet, after importing the file to FCP I don
    Trevor Ward replied 20 years, 9 months ago 5 Members · 7 Replies
  • 7 Replies
  • Tom Wolsky
    December 21, 2005 at 11:25 pm
    Make sure it was made on a Mac and that you’re not using 16-bit.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” DVD
  • Gs2005
    December 21, 2005 at 11:54 pm
    I’m creating the Photoshop doc on a PC machine, how can i use the layers in FCP/Mac ?
    Thx for your help
  • Todd Beabout
    December 22, 2005 at 12:17 am
    Open it in PS on a Mac, then re-save. It should then open with layers in FCP. Remember to flatten each layer if you have applied FX or styles to them in PS or it won’t translate over.
    Good luck!
    -Todd Beabout
    Vazda Studios
  • Gs2005
    December 22, 2005 at 12:34 am
    I have a pc version only not for the mac …
    Any suggestions ?
  • Tom Wolsky
    December 22, 2005 at 12:38 am
    Save each layer as a separate PSD file and import them into FCP. That’s the only solution you have.
    All the best,
    Tom
  • Arnie Schlissel
    December 22, 2005 at 5:01 am
    Gimp will open & save in photoshop format. And it’s free. gimp.org
    Arnie
    https://www.arniepix.com
  • Trevor Ward
    December 22, 2005 at 12:07 pm
    I know the answer to this one. make sure it is an 8-bit file. I’ve had the same problem before. Doesn’t amtter if its from PC or Mac.
    BTW, when you say you don’t see the layers, do you mean that when you double click on the “sequence” of the psd, there is only one video track in the timeline? Or, do you mean that you only see one psd file in your bin?
