Activity Forums Adobe Photoshop Photoshop – export video render problem
  • Photoshop – export video render problem
    Posted by John Maguire on October 4, 2012 at 3:19 am
    I’m working on Photoshop CS4 Extended in the video workspace- retouching scratches and specks on an AVI video file scanned from old film (DV, 720 x 576 (768 x 576), Millions.) I am not finished but tested exporting the retouched video out of photoshop, so I tried to export via “render video” as an AVI file (PAL D1/DV, 720 x 576, no compression, millions of colors.) It apparently processed successfully, but when I attempted to play the file, it was just a black field that played through the entire time of the clip. Any tips would be appreciated. Thanks.
    Andrew James replied 13 years, 11 months ago 2 Members · 2 Replies
  • Andrew James
    October 15, 2012 at 4:45 am
    In Photoshop export video render depends on the capacity of the computer you are using. The higher the specification the faster the rendering. Also during the rendering make sure that only the adobe Photoshop are running in your unit. https://saltlakecitystudio.com/
  • Andrew James
    October 15, 2012 at 6:58 am
