Activity Forums Adobe Encore DVD Photoshop error -1 when I build BD.
  • Photoshop error -1 when I build BD.
    Posted by Adam Berch on August 22, 2019 at 4:50 pm
    I am using Encore 5.1 on El Capitan Version 10.11.2
    I have used Menus in Encore and made a BD. When I press build (I am making an ISO File). it starts to work then it stops and says “Photoshop Error -1”.
    What is this and how can I fix it?
    Thanks in Advance
    Adam Berch replied 7 years, 1 month ago 1 Member · 1 Reply
  • Adam Berch
    August 24, 2019 at 10:14 pm
    Hi.
    I am using Encore 5.1 on El Capitan.
    What do you mean “you cannot export 5.1 from Premiere without a plugin?”
    I have built a 2 Hour BD in Encore with 5 Menus (1 Main and 4 Scene Selection Menus). I have music on each menu.
    I have used menus that come with Encore. I try to put more buttons on the menus, but every-time I try and drag a button to the menu in Encore, it crashes the software.
    I have edited them in Photoshop. When I need more buttons I just copied them from the menu while I am editing it in Photoshop.
    I Check it and there are no problems with the BD.
    I set it up to build (25 GB BD, and I am going to build it so it makes a BD Image File).
    When I press Build, it starts going for about 2 minutes then it stops and the error message comes up “Photoshop File error -1.” Then it stops building.
    Why does it do that? Do I need a plug in for that so it will finish the BD Build? If so, where do I get the plugin and what is it called?
    Thanks in advance
