Activity Forums Adobe After Effects Photoshop equivalent
  • Photoshop equivalent
    Posted by Trugmolly on July 11, 2005 at 2:08 pm
    In photoshop a technique that I use a lot is to create transparency in a layer and then lock the transparency only. This allows one to paint or manipulate the remaing portions of the image and the transparency remains unaffected
    Is there something similar in AfterEffects ?
    Peter
    “thats my story and I’m stuck with it”
    Trugmolly replied 21 years, 2 months ago 3 Members · 4 Replies
  • Josh Michnik
    July 11, 2005 at 2:25 pm
    precompose the layer
  • Trugmolly
    July 11, 2005 at 3:46 pm
    Thanks. I am did that. Not sure though that it is exactly what I wanted.
    I want to lets say use the vector paint tool. If I had the transparency locked then I could just use a massive brush and it would only paint the
    parts of the image that were the visible elements. In photoshop you could just ‘fill with bkg colour’ the transparency remains transparent.
    I hope that explains it a bit better.
  • Chris Smith
    July 11, 2005 at 7:56 pm
    use a mask or track matte.
    A mask only allows the RGB to be seen whithin it (At default settngs at least).
    A track matte will allow you to use the alpha (Transparency) or luma (from the RGB) from another layer as it’s own alpha.
    So for example, if you made the text ‘Trug” on one layer. Then just washed another layer with colors and whatever, you could use the alpha from the Text layer to isolate where the colors show. So you would have an image with your wash of color only whithin the word ‘Trug’.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Trugmolly
    July 11, 2005 at 9:24 pm
    Got it covered, Cheers
