Activity › Forums › Adobe Photoshop › Photoshop effects layers?
Posted by Sunriseseagull on November 29, 2006 at 11:36 pmHi everyone,
Is it possible to edit a filter that has already been applied on a layer? I mean like the Effect Controls in AE and Premiere Pro. Thanks a lot in advance!
Sunriseseagull replied 19 years, 9 months ago 3 Members · 4 Replies -
Tim Kurkoski
November 30, 2006 at 7:55 pmOnce you apply a filter to a layer, it’s set in stone. However, there are two things you can do to get around that:
1. Adjustment layers. These only work for the pre-defined adjustment options (like levels, curves, etc.), but you can tweak them later. What you can also do is apply filters to these layers, and while they aren’t any more editable than they were before, you can do things like vary the opacity of the layer to change how much it affects the layers below it.
2. Layer Effects. These work pretty much the same as how AE works with effects, but as with adjustment layers there’s a limited set of effects that you can use.
Also, consider using Smart Layers. They allow non-destructive transformations (rotate, scale, etc.), and make it easier to revert to your original layer. (You are saving a copy of your original layers or files before you apply filters to them, right?)
Sunriseseagull
November 30, 2006 at 10:45 pmThanks, Tim!
I always save a copy before working on the image and I’ll try out with your suggestions. So, basically there’s not much to do when it comes to apply a filter or 3rd party plugins? Thanks!
Jim Kanter
December 4, 2006 at 9:50 pmThat is correct. Photoshop is a destructive editing environment.
Many people are switching to After Effects (even for still image work) because it is non-destructive editing. You can go back and change pretty much anything at any time if you (or the client) change your minds.
Jim Kanter,
Digital Film Institute
http://www.dfilminst.com
