Activity Forums Adobe After Effects Photoshop document not importing in layers
  • Photoshop document not importing in layers
    Posted by Timi Boose on February 1, 2012 at 6:16 am
    Hi. I have imported multilayered Photoshop documents into Aftereffects before and they worked fine, but someone sent me one with 5 layers and no matter how many times i try importing it, it only comes over as one flattened layer.
    I select to import it as a composition and it does import as a composition but when I open the composition there is only 1 layer there! ( I also made sure all the layers in the Photoshop file were on ((eyeballs)))
    Any Ideas before I lose my mind before I can even get started with the Aftereffects part of this job?!
    File not found – Bad serial number – the problem could be this, that or the other…
    Krystal Schultheiss replied 12 years, 9 months ago 5 Members · 5 Replies
  • John Cuevas
    February 1, 2012 at 12:36 pm
    Offhand, no idea why it’s not working, but you can upload the file here and I’ll take a quick look at it and see if I notice anything strange.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Angie Taylor
    February 1, 2012 at 2:13 pm
    Hi there,
    The file may have been corrupted so try opening it in PS and resaving it as a copy.
    If this doesn’t work, check that you don’t have the “Import as Sequence” option ticked in the AE Import dialog box. That can screw things up and it’s not obvious to spot. Has caught me out a few times! 😉
    cheers,
    Angie
    Angie Taylor animation & illustration for television, film, web and devices
    https://www.angietaylor.co.uk
    Twitter: theangietaylor
    Linkedin: theangietaylor
    https://www.facebook.com/pages/Angie-Taylor/118378194869002
  • Michael Szalapski
    February 1, 2012 at 3:03 pm
    Also make sure the color mode in Photoshop is RBG, not CMYK or some other odd color mode.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Timi Boose
    February 1, 2012 at 4:23 pm
    Thanks for the answers everyone! it turns out the Photoshop document was in CMYK . It worked perfectly fine after I changed it to RGB.
  • Krystal Schultheiss
    November 4, 2013 at 12:25 am
    thanks for that, that was killing me!
