Activity Forums Adobe Photoshop Photoshop CS – inserting a watermark logo, batch process. help!
  • Photoshop CS – inserting a watermark logo, batch process. help!
    Posted by 409industries on October 13, 2005 at 7:04 pm
    ok so heres the deal.
    I know how to use text to watermark a ton of photos all at once (using the action pallette).
    My question is this, how can i insert another jpeg image (logo) into all the pictures in a set batch? I tried recording the action but run into problems pasting into the original image because photoshop can no longer “select previous image” when the next file comes along in he batch.
    I know there has to be a way because if you look at most websites, they use translucent logos. It would be such a pain to put that logo on each page one by one. Also how can i make sure each logo is aligned correctly to the bottom right corner?
    any tips would be greatly appreciated. am i going about processing batches incorrectly?
    heres what i am using so far as an action:
    >Image Size (resize to 800×600)
    >Open (this opens the logo file that will be used for watermark)
    >Copy (copies logo to clipboard)
    >Select Previous Document (selects target image for the watermark logo to go into)
    >Paste
    >Move Current Layer (aligning to the bottom right… this may not be the best way to do it)
    >Set Current Layer
    >Export (save for web function, jpeg – High)
    409industries replied 20 years, 11 months ago 2 Members · 2 Replies
  • Seth Taylor
    October 14, 2005 at 4:24 pm
    I don’t have the time to try it right now, but could you make a custom brush (or custom shape) with your watermark and set that in your action to be positioned at the correct location.
    utah dvd replication – stotion.com
  • 409industries Create COW Profile Image
    409industries
    October 20, 2005 at 7:12 pm
    I eventually figured out how to do it.
    It required copying the image i wanted to use onto the clipboard first, and having the image i was going to watermark highlighted before starting to record the animation.
