Activity › Forums › Adobe Photoshop › Photoshop crashes on launch
  • Photoshop crashes on launch
    Posted by Walter Miale on August 6, 2013 at 5:56 pm
    I’m running Photoshop CS2 on an iMac with OS 10.5.
    Out of the blue, the application just crashed, and now crashes on launch. Is there an alternative to re-installing?
    If I do have to re-install, are there some tips I should know? Do I have to un-install first?
    Of course my deadline is day before yesterday.
    Thanks.
    Walter Miale replied 13 years, 1 month ago 2 Members · 2 Replies
  • Jeff Hinkle
    August 6, 2013 at 6:33 pm
    You can try trashing your preferences file. Go to
    /Users/[Username]/Library/Preferences/Adobe Photoshop CS6 Settings and delete the file Adobe Photoshop CS6 Prefs.psp
    You might also want to trash /Users/[Username]/Library/Preferences/com.adobe.Photoshop.plist
    You can also try holding down Command-Option-Shift when starting Photoshop to do the same thing, but since I didn’t know how far in the startup you were getting before it died, I figured the manual route was better.
    Hope this helps!
    It is easier to destroy than to create.
    More fun, too.
  • Walter Miale
    August 6, 2013 at 7:48 pm
    Thanks very much. Before trying your suggestions, I tried re-launching PS for about the seventh time. Guess what!? It worked…………. I’ll save trashing prefs for next time.
