Activity › Forums › Adobe After Effects Expressions › Photos to movie via AE
  • Photos to movie via AE
    Posted by Geof Gilland on August 23, 2006 at 12:58 pm
    I needed to create a movie with about 100 stills in AE. Each photo had a move and scale applied to it. The move and scale were not repeatable because each photo was composed differently. At the end of each photo, a fade out was done with transparency.
    But In the end, instead of 4 seconds for each photo, I needed to change the time to 5 seconds per photo.
    Was there an easy shortcut to applying a time change to every photo? Maybe something with expressions?
    Thank you in advance.
    Filip Vandueren replied 20 years, 1 month ago 3 Members · 2 Replies
  • Nicholas Toth
    August 23, 2006 at 3:27 pm
    Layer>time>time remap
    Stretch the time.
    Or if you have production bundle
    Effect>time>timewarp and set the speed to 75%.
  • Filip Vandueren
    August 23, 2006 at 8:51 pm
    You can just precompose your final comp, collapse geometries, and do a stretch of 125% on that layer.
