Activity › Forums › Apple Final Cut Pro Legacy › photoJPEG or DV50 for archive?
  • photoJPEG or DV50 for archive?
    Posted by Guy on October 31, 2005 at 8:49 am
    If I am archiving hi-8 footage which would give the best quality: photoJPEG @ 75% or DV50? Would going past 75% with photoJPEG be worthwhile? Would bitjazz or another codec make more sense? I’m looking for the best balance of quality and filesize.
    Sean Oneil replied 20 years, 11 months ago 4 Members · 6 Replies
  • Chris Tompkins
    October 31, 2005 at 12:28 pm
    DV50 is the higher quality codec
  • Graeme Nattress
    October 31, 2005 at 2:51 pm
    I think you’ll find that PhotoJPEG75% is better even than DV50, and nearly the equal of uncompressed. There’s no point going beyond 75% to 100% as PhotoJPEG100% is RGB(4:4:4) whereas 75% is Y’CbCr(4:2:2) which is still overkill for hi8.
    Graeme
    – http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Sean Oneil
    October 31, 2005 at 6:45 pm
    Yes, exactly what Gramme said. PhotoJPEG is quite a bit better. 75% quality is what you want – it’s virtually lossless, much like the Digibeta codec.
  • Sean Oneil
    October 31, 2005 at 6:48 pm
    BTW, check out:
    http://www.onerivermedia.com/codecs/
    That site is fantastic. He did a 10 generation test for most codecs. DV50 was very lossy while PhotoJPEG was almost identical.
  • Guy
    October 31, 2005 at 9:45 pm
    Cool. Digibeta quality and possibly smaller files than DV25! The only downside I see is no RT FX in FCP. Is that because photoJPEG use up more processor power than DV50?
  • Sean Oneil
    November 1, 2005 at 7:20 pm
    Yes, sort of, but it’s really an intentional thing by Apple. There’s a hack to give you RT effects with P-JPEG. Kind of complicated to explain though.
