Activity Forums Apple Final Cut Pro photographic movie workflow
  • photographic movie workflow
    Posted by Paul Godard on August 31, 2012 at 10:37 pm
    Hi
    I am doing photo movies using hires images mixed with motion animations.
    1/ My projects are always 1080p at 30 fps. Is this correct?
    The final production are either played on a PC (Mac or Win), using a projector or not, on the web or on a dvd (SD or blue ray).
    I generally export the project using ‘send to projector’ as ‘apple pro res 422’, then either directly from the project or later from the exported PR422 file, I created the other versions using different presets.
    2/ Here is the preset I am using to play the 1080p on a PC. Is this correct? What is the best settings for best quality and smallest file size in this case?
    Description: H.264 1080p for PC at 5 Mbps
    File Extension: mp4
    Estimated size: 2.27 GB/hour of source
    Audio Encoder
    Sample Rate: 22.050kHz
    Channels: 2
    Bits Per Sample: 16
    AAC encoder quality: high
    Data rate: 40 Kbps
    Video Encoder
    Width: (100% of source)
    Height: (100% of source)
    Pixel aspect ratio: Default
    Crop: None
    Padding: None
    Frame rate: (100% of source)
    Selected: 29.97 ——————— why this if it is 30 fps in the original file?
    Frame Controls: Automatically selected: Off
    Codec Type: H.264
    Multi-pass: Off, frame reorder: Off
    Pixel depth: 32
    Spatial quality: 75
    Min. Spatial quality: 75
    Key frame interval: 90
    Temporal quality: 75
    Min. temporal quality: 75
    Average data rate: 5 (Mbps)
    Video: H.264 main profile
    Enhanced Podcast: Off
    Compatible with Mac and PC
    The original movie PR422 is 6.2 Gb and the PC-1080 above is 165 Mb with very good quality.
    3/ How comes that if I changed the geometry to limit the size to 1280 x 720 the file size does not change (161 Mb)?
    Paul Godard – Soul Photography
    Paul Godard replied 14 years ago 1 Member · 0 Replies
  • 0 Replies
