Activity › Forums › Adobe After Effects › Photo Mosiac and Card Dance
  • Rhett Robinson
    January 14, 2008 at 2:52 pm
    Not sure of the question – need more specificity.
    As you can see, Ayato usually shows starting values on left, ending values at bottom right… he’s also big on saying to adjust to your liking.
    The main things are to know to ONLY turn visibility on your mosaic layer, and use the other to drive the card dance.
  • Note Suwanchote
    January 15, 2008 at 4:21 am
    well, overall it seems like I specifically just need what parts to animate.
    And thats it.
    Thanks.
  • Rhett Robinson
    January 15, 2008 at 4:44 am
    Ooohhh..
    I was about to harass you, then I opened up and old project where I worked it, and understand that the timeline isn’t as clear, as you can’t tell which “multiplier” goes with each. I just worked with it until I determined which ones but using this old project as a guide, here goes…
    all animated parts in the timeline shown are for the Card Dance plugin, after setting the initial settings shown on the first screen
    https://www.ayatoweb.com/ae_tips_e/ae50_e.html#
    the order for the timeline as follows
    The first 2, multiplier and offset are for Z-position
    the next 2 multipliers are for the X & Y scales
    the next 3 (z rotation, xy position, z position) are under the “camera position” setting
    I adjusted some other things as well, but that should get you through that part…
    good luck!
  • Note Suwanchote
    January 15, 2008 at 5:55 am
    thanks
    all in all
    works very well
    also sent you another email
  • Rhett Robinson
    January 15, 2008 at 2:26 pm
    Sorry, went searching for an e-mail with no luck – if you give me a keyword in it or a cryptic version of your address to hide from spammers – let me know!
    Rhett
  • Ian Cheah
    February 10, 2010 at 4:43 pm
    Hi guys,
    I was gonna try the same tutorial as well and stumbled up your thread.
    wish me luck! 🙂
