Activity Forums Adobe Premiere Pro Photo montage – any help please
  • Photo montage – any help please
    Posted by Michael O’brien on June 26, 2008 at 10:07 am
    I have created a photomontage in premiere with a lot (500+) of still shots. I have set markers on the timeline to the beat of the soundtrack that I have added and placed the stills at these markers.
    When I play back the film in premiere, the slides/stills are perfectly in time but I can’t for the life of me figure out an export setting that will keep it in time. Everything I try looks and sounds great but the timing is way out. Does anyone have any suggestions?
    I am looking to export one smaller version for the web and then a high quality version which will then be projected.
    Any help much appreciated,
    thanks.
    Perry Cheng replied 18 years, 2 months ago 4 Members · 4 Replies
  • Terry Kampowski
    June 26, 2008 at 11:26 am
    The only thing I can think of has to do with the size of the pictures you’re using in Premiere. If you’re using 8 MB pictures at full resolution times 500 – that could need an extreme amount of processing power and might be causing your problems.
    Try working on a new section, but bring the pictures in at the default size 720×480 and see what that does.
  • Michael O’brien
    June 26, 2008 at 7:52 pm
    Hi Terry,
    Thanks for the response. The pictures are only 720 x 480 so that shouldn’t be a problem.
    Just can’t work it out!
  • Todd Roush
    June 28, 2008 at 5:01 am
    In a pinch you can dump it back to your DV camera then re-import and see if it works better that way.
    Things should not be out of time when exporting so there’s some funny business going on.
    Good luck
    S.
    Todd Roush
    Dreamscape Digital Media
    Panny DVX-100’s but changing so Sony or Cannon HDV soon.
  • Perry Cheng
    June 28, 2008 at 6:12 pm
    How do you export? settings?
    Perry
