Forums › Web Design (WordPress, Joomla, etc.) › Photo Links In Columns
John-Patrick Crowe
July 8, 2019 at 1:31 amHey!
I want these photo links to be in 3 columns, but unfortunately the “Mr. Bannock Food Truck Design” text doesn’t stay underneath the food truck picture. What’s wrong with my code?
https://codepen.io/jpcrowemedia/pen/BgqyEw
Thanks for your help!
Bret Williams
October 7, 2019 at 9:51 pmYou’ve probably got this figured out by now but I just ran into it. I think with columns, at least in Elementor, keeping things even and tidy trumps everything else. To make sure it displays as you wish you’d be better off just making 3 individual columns. Especially since you’re not wrapping text from one column to the next. The kind of layout you have here makes more sense with lots of text.
Are you using Elementor btw? Makes this stuff easy for a non-coder like myself!
______________________________________________________
https://BretFX.com FCPX Plugins & Tutorials
NEW PLUGIN – Text Message 2! ON SALE Through 10/7/19
NEW TUTORIAL – Animate Text in FCPX without Keyframes or Plugins
https://youtu.be/GlD_aLgEk1U/John-Patrick Crowe
October 8, 2019 at 5:31 amHey thanks for the reply. I was just copying and pasting code I was finding on the internet because I am also not a web designer.
The solution I found was to use Squarespace’s drag and drop feature. You can form three columns by dragging and dropping your images.
Log in to reply.
