Activity › Forums › Compression Techniques › Photo jpeg compression
  • Photo jpeg compression
    Posted by Chris Walker on September 12, 2009 at 3:11 am
    Hello,
    I’ve been having problems with a color/luminance shift when exporting to the photo jpeg codec out of an avid timeline. The footage looks great in the avid, but when I export using photo jpeg it becomes a little washed out and looses some saturation. I am encoding at best quality, have no filters on at export, using a Mac with QT7. I know there is a known gamma shift with H.264, so are there any known problems with the photo jpeg codec and any workarounds to fix it? I have to supply footage using this codec but want it to look right. Sorry if this is a stupid question, but I’m a bit of a newbie. Any help will be greatly appreciated. Thanks.
    Chris Walker replied 17 years ago 2 Members · 4 Replies
  • Daniel Low
    September 12, 2009 at 9:58 am
    [Chris Walker] “I am encoding at best quality”
    How far to the right is the quality slider in the PhotoJPEG compressions setting options?
    “There’s no chance that the iPhone is going to get any significant market share. No chance.”
    Steve Ballmer To USA Today
  • Chris Walker
    September 13, 2009 at 12:55 am
    It’s at 100%. But I’ve also tried it at 90% and the same thing happens (although the file size is quite a bit lower).
    Has anyone heard of this happening with this codec? I’m at a bit of a loss as to how to fix it.
  • Daniel Low
    September 13, 2009 at 7:19 am
    What format of video are you editing? It may well be that what you are seeing is the effects of colourspace conversion from the timeline of 4:x:x to the 4:4:4 of the PhotoJPEG codec.
  • Chris Walker
    September 14, 2009 at 9:49 am
    The footage is all 4:2:2. So if that’s the problem, is it possible to fix it?
    I also did a test by dropping the quality to 75%, because I read that the codec drops to a 4:2:2 color space at 75%, but it still has the same shift. Does this mean that it will always happen with this codec?
