Activity › Forums › Adobe After Effects › Photo Jpeg Compression–black screen
Posted by Johnsabbath D’urzo on July 10, 2009 at 7:09 pmI have HDV footage and transfered it to photo jpeg. When I put the footage in the timeline in AE I can see the footage , on ram preview I can not see the footage the screen goes black. In the same timeline as a test I drop DVCPRO HD footage and the footage is good on preview is this normal? if not how can i fix?
Kevin Camp replied 17 years, 2 months ago 2 Members · 5 Replies -
Johnsabbath D’urzo
July 10, 2009 at 7:18 pmJust did a render in AE and the footage plays choppy in FCP when using photo jpeg 1440×1080 compression from AE, I get lots of errors in final cut about drop frames.
Johnsabbath D’urzo
July 10, 2009 at 7:21 pmDave, just checked the footage and the file was the right one, any suggestions? is this a normal thing to use footage in AE with photo jpeg compression?
Johnsabbath D’urzo
July 10, 2009 at 9:36 pmDave, the timeline and the codec match, still getting playback errors. My drives are lacie @ 7200 rpm with a powermac g5 quad. Is there anything else I can check?
Johnsabbath D’urzo
July 10, 2009 at 9:54 pmhere is the info to my drive
LaCie d2 Quadra Hard Disk
eSATA 3Gbits | USB | FireWire 400 & 800
500GBFully loaded with all the best interfaces—eSATA 3Gb/s, FireWire 800, FireWire 400, and USB 2.0—this all-in-one professional hard disk offers universal connectivity for PC and Mac users. For easy setup, the LaCie Setup Assistant helps format your disk according to your needs. Perfect for digital content creation, audio/video editing, DVD authoring, Web animation, etc., the d2 Quadra can handle multiple demanding professional tasks. It can be daisy-chained via FireWire or connected to your DV camera and is even bootable in FireWire for Mac and in eSATA for Mac/PC. With the LaCie Shortcut Button***, you can easily launch any application in one push, such as the included Genie Backup Assistant software with data restore for Windows or Intego Backup Assistant software with data restore for Mac. The unique, fanless aluminum heat sink design with 60% more surface area for heat dissipation keeps it quiet and safe.
Would you think its a drive? or i can’t think of any settings. Let me know what you think. Thank you.
What kind of drives do you have? What kind should I look into?
Kevin Camp
July 13, 2009 at 1:57 pmto get the fastest throughput from that drive, you’d need to be connected via the esata interface. to do that you’d likely need a esata pci host adapter (or pcmcia card if you have a laptop). otherwise you’re using interfaces that probably can’t handle the data rate of photo-jpeg.
dvcprohd will work with firewire800, and would be a good option for you. it is better than the hdv footage that you have, plays nice with both after effects and fcp and will play/record smoothly using firewire800.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
