Activity › Forums › Blackmagic Design › Photo Jpeg Blackmagic outputs – settings?
  • Photo Jpeg Blackmagic outputs – settings?
    Posted by Mike J. on January 6, 2006 at 7:14 pm
    I used blackmagic drivers with the old kona cards…but it used to be that when you used photojpeg you chose a JPEG OUTPUT setting in the VIDEO OUTPUT settings of Final Cut and there it was.
    Well, with this brand new Blackmagic card installed…I see that choice is actually no there. When I choose 8bit blackmagic…it does output but on stops there is big color/luma shift.
    How should I set up PHOTO JPEG outputs correctly?
    Mike
    Mike J. replied 20 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
