Activity Forums Adobe After Effects Photo fly through
  • Photo fly through
    Posted by David Hetzer on August 9, 2007 at 10:44 am
    I am trying to create an effect where the camera zooms into a photo to the point where the photo becomes a mixture of dots.(like magnfiying a newspaper photo) The camera would zoom through those dots to reveal another photo. Any ideas on how to create the effect would be appreciated.
    Kevin Camp replied 19 years, 1 month ago 2 Members · 1 Reply
  • Kevin Camp
    August 9, 2007 at 2:06 pm
    take a look at ayatoweb.com. he has a few tutorials there that may be very helpful… in particular examples 49, 50 and 52.
    also a couple of free effects, retrodots and halftone (part of pete’s plugins) that may help you ‘halftone’ your image.
    both of those will only generate a halftone patten based on luminance, if you need a color halftone, you may need to find a different effect. or, separate the channels of your image using channel combiner on separate duplicates of the image setting each r, g or b channel to luminace only. then applying one of the halftone effects to each layer, modifying the angle as needed. then colorizing the halftone dots to the appropriate color.
    or possibly do it in photoshop, which will give you a cmyk dot pattern, which would be more like a newspaper.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
